AC Motors
Discussion in 'General Electronics Chat' started by sparksaflyin, Nov 30, 2013.
  1. sparksaflyin
    Nov 30, 2013
    What type of motor is it? I recently repaired the controller for an old Craftsman Bench Grinder, which operates on 120V AC single phase. It has a speed controller circuit using a Triac as the switch (and DIAC trigger), and applies a full wave rectified line voltage to the motor. The motor is rated as 1/5 horse power. At low speed there is hardly any torque at the output shaft. I thought at first that it is a Shaded-pole motor, but can't confirm that from the outside. It has two brushes contacting a rotor.
  2. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,513
    It is a Universal series connected motor and will operate on AC or DC.
    Without feedback of some kind the torque will be much lower as the voltage is reduced.
    Max.
  3. sparksaflyin
    Nov 30, 2013
    Thanks Max for the quick response.
