AC motor driver that can handle 11 amps
Discussion in 'General Electronics Chat' started by aidayley, Sep 6, 2016.
  1. aidayley
    Jul 26, 2016
    63
    7
    I am looking into making a ac motor driver, it needs to be able to handle 11 amps at 125 volts. I have not been able to find a suitable schematic
    AIDayley
  2. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    What type of AC motor, induction, 1ph 3ph, universal?
    Max.
  3. aidayley
    Jul 26, 2016
    63
    7
    1ph
  4. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    What technology? there are all kinds of AC 1ph motors, Universal, shaded pole, capacitor start, PCM (permanent cap start), if this a 1.5 hp motor 1ph induction motor the chances of reliably controlling the rpm's are relatively nil.
    They do not control well under load and at low rpm.
    What is the purpose behind the control?
    Max.
  5. aidayley
    Jul 26, 2016
    63
    7
    I know one of the motors which I would use it on is a 0.5 hp cap start induction the other is on a radial arm saw all it says is "ball bearing motor"
  6. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    There are extremely few manufacturers of RPM control for 1ph induction motors, mainly the ones available are only usefully for light duty, fans etc.
    A simple small shaded pole motor can be controlled by a Triac style very cheaply, mainly used for ceiling fans etc.
    Max.
    aidayley likes this.
