I have been tasked with researching and building a circuit that will detect one delta on an ac motor that will range from one volt AC to 28 volts AC. The goal is to detect the moment the motor starts to run 1 VAC and flip a 24/36 VDC relay to control a Hydraulic Valve.
The system is a hybrid AC / DC system that uses industrial grade battery packs as a back up with DC to AC amplifiers to drive some of the high output motors.
does anyone know of a simple single device to achieve this or am I stuck designing some sort of OP Amp relay driver?
STUCK...
STUCK...
