The motor came with a wired in cut off switch for when the motor is pulling wire in. However I'm trying to wire the motor to wear the cut off switch doesn't allow the motor to let out. The motor is a 1300 pound electric hoist. Can't get the motor to be able to pull cable in while not allowing the motor to let cable out (when the normally closed switch is open). The original wiring had the switch wired in parallel with the capacitors.
