Drill motor reversing switch is not working. No replacement is available. Would like to eliminate this and the power switch and replace with a simple toggle switch. Question is how to wire the brushes. Does one brush get the hot wire feed (black ) and the other get the neutral (white) or are both brushes hooked up to hot feed (black)
