Hi..
Hoping someone can offer a suggestion. I need a low cost motor to run at about 100-200 RPM for 15-20 minutes at a time once a day. The motor will drive a sifting screen back and forth 4 or 5 inches to sift manure from clean bedding in horse's stalls. I tried an old single speed drill on a dimmer (which I doubted would work..it did briefly then it burned up) I then tried a 3.5 amp variable speed drill which worked great until it heated up and started smoking after a few minutes. I am assuming these motors are not meant to run at restricted RPM's for any period of time. I thought about a larger, heavy duty drill but thought I may run into the same problem. Any suggestions on a cost efficient solution? The link will take you to a short video of the machine. Your insight would be appreciated.
http://www.youtube.com/watch?v=tcOcwWF-rSQ
chris
chris
