AC mesh analysis and power calculations
Discussion in 'Homework Help' started by regexp, Jan 2, 2011.
  1. regexp
    Nov 20, 2010
    In this circuit.
    I need to determine the power dissipated in the resistance and also the reactive power delivered to the source V1.
    Starting by writing the mesh equations for I1:
    8I_{1} -I_{1}\cdot J2 + I_{2}\cdot J2 = 40
    I_{2}J2 -I_{1}J2 +I_{2}J4 = -j20
    Subtracting the second from the first gives
    8I_{1} -I_{2}J4 = 40+j20
    The correct answer is supposed to be 8I_{1}-J4I_{1} = 40+J20
    I don't really see where i went wrong =/
  2. edgetrigger
    Dec 19, 2010
    your answer is right. Even i am getting the same result. Its almost ten years that i dealt with mesh analysis, but i don't see why i shouldn't concur with you.
  3. bglazierjr
    Apr 2, 2011
    I know this is a little late but it seems to me that you've mixed up your signs on the second equation
    If written using the format approach you will get -I1(-j2)+I2(-j2+j4) = -20j
    which simplifies to be I1(j2)+I2(j2) = -20j
    Now if you use a calculator such as the ti-89 or ti-86 you can enter the coefficients in directly to solve for the current I1 and I2. A lot of people complain about not being able to do this with an ti-83 or 84 but you actually can with an extremely simple program. If you want I can type the source out.
    I1= 3 + 4j -----> 5A< 53.13 degrees
    I2= -13-4J -----> 13.6A< -162.9 degrees
    I assume you mean the power dissipated in the resistor.
    VR1 = 8ohms * 5A< 53.13 degrees = 40 V < 53.13 degrees
    40V < 53.13 degrees * 5A< 53.13 degrees = 200 Watts < 106.26 degrees
    PV1 = 40V * 5A< 53.13 degrees = 200watts < 53.13 degrees
  4. bglazierjr
    Apr 2, 2011
    Opps I mean the power is 5/sqrt(2) * 40V / sqrt(2) * cos (0) = 100Watts
    and PV1 is 5/sqrt(2) * 40V / sqrt(2) * cos(53.13) = 60 watts
    where x= phase shift between voltage and the current for cos(x)
