AC LR-C parallel circuit
Discussion in 'Homework Help' started by monkeyhead, Feb 29, 2008.
  1. monkeyhead
    Thread Starter Active Member
    Mar 5, 2007
    45
    Hi there!
    Basically I'm ploughing through my assignment and trying to work out the phase angles of a capacitor, of the coil and of the supply.
    I was given the values as follows:
    Supply: 260V @ 50Hz
    Inductor: 31.831mH
    Resistor: 24 Ohm
    I had to work out the value of the cap which I worked out as: 47.1 uF
    My attempt
    Note: Results given rounded to 2dp.
    I worked out that the current through the coil and its phase angle as follows:
    Current: 10A
    Angle: 23º
    ( I did this by working out Xl, then the impedance then using ohms law and results were similar from simulation)
    I also worked out the current in the cap and its phase angle as follows:
    Current: 3.85A
    Angle= 90º (as it leads)
    ( I did this by working out Xc, then using ohms law and results were similar from simulation)
    Now for the supply angle and its current I did the following.
    I worked out the the total horizontal component which was = 9.21A
    Then did the same for the vertical components and that calculated at = -0.06
    Then calculated I by doing the following I= √((9.21)²+(-0.06)²)= 9.21
    To get the angle I used inverse tan as follows:
    tan-1(0.06/9.21)=0.37º
    To me this angle seems way to small?! Have I gone wrong somewhere?
    Many thanks,
