AC load and DC load
Discussion in 'General Electronics Chat' started by superway, Aug 16, 2011.
  1. superway
    Thread Starter Active Member
    Oct 19, 2009
    128
    I built a resistor load bank that is using for AC load (90vac) testing. So can I use this AC resistor load bank for DC load ( 48vdc) testing? or do I need to build a special load for DC voltage only?
  2. praondevou
    Jul 9, 2011
    2,936
    489
    You can use this load bank for DC too. Make sure you stay within the ratings of the resistors (which should be the case since they were rated for a higher voltage) and the max. output current of the DC-source.
  3. iONic
    Nov 16, 2007
    1,422
    68
    resistors don't care what you toss at them, nor from what angle or direction. Their job is to stop what you are tossing at them, within their designed limits.
