Hi everyone,
What is the simplest way to create an AC voltage level shifter which will shift a 0-10V P-P signal down to +/-5V P-P? The frequencies I'm working with are from about 100Hz to 3KHz.
I would like to avoid using a negative supply if possible, but will if it is necessary.
