AC-LED circuit problem 1.6V instead of 3
Discussion in 'The Projects Forum' started by smilem, Nov 17, 2010.
Thread Status:
Not open for further replies.
  1. smilem
    Thread Starter Senior Member
    Jul 23, 2008
    133
    Hi, I'm trying to power a LED for a switch as indicator.
    The switch is 230AC 3 pins, and indicator must be mounted away from the switch.
    I have simulated this circuit I found elsewhere and in simulation it works fine, except in real world I get only 1.6V and LED is very dim.
    Any ideas? all parts are like in simulator resistors are 1/2W
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Transformer-less LED drivers can be very dangerous. Best to use a cheap wall wart.
  3. smilem
    Jul 23, 2008
    133
    Yes I know about the dangers.
    Well this is for use as indicator light that an appliance is on (LaserJet printer, YES HP forgot to put ON/OFF switch), I could use neon light but I want to use LED. The LED is better because low voltage at the LED side, and it looks better instead of flickering neon. Besides I already have all parts.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Be aware you can be killed trying this.
    Use X1 rated/type caps for fail safe in the event you want to go forward, but a neon lamp would be a better solution.
    This thread will be most likely locked due to rules.
  5. smilem
    Jul 23, 2008
    133
    The wires running to LED are not 230Volts so it's safer than having a neon lamp with 230V am I not correct? Everything will be encased inside a printer, if you did not know printers run on 230V so it will not be more dangerous putting this led inside than it already is.
    But I can't seem to get required 3V.
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    If you are using it as an indicator in a laser printer, look for a low voltage to connect the led.
    We do not want leds connected directly to the mains.
    Bertus
Thread Status:
