AC Laptop adoptor
Discussion in 'The Projects Forum' started by yubaraj, Oct 24, 2011.
  1. yubaraj
    Oct 22, 2011
    6
    Hey I am doing my minor project in DC adaptor having following input
    110-240v Ac , 50 Hz
    Output- 19.5V Dc.
    Can anyone help me how to simulate the adaptor circuit in matlab simulink which can give the constant dc output voltage of 19.5v DC from the variable ac voltage source from 110v to 240v Ac at 50HZ frequency?
  2. ogbuehi
    Jan 13, 2011
    Sounds like you'd need a simple rectification circuit.
    yubaraj likes this.
  3. BillB3857
    Feb 28, 2009
    2,402
    348
    With the input range specified, it will be a little more complex than a simple rectifier circuit. Think SMPS (Switch Mode Power Supply)
    yubaraj likes this.
  4. chrisw1990
    Oct 22, 2011
    543
    41
  5. chrisw1990
    Oct 22, 2011
    543
    41
    just make sure you match the current for the laptop (assuming you are going to use on a laptop)
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    This sounds more like a school lab project than a need for a laptop PS. Am I correct?
  7. chrisw1990
    Oct 22, 2011
    543
    41
    could be right hence the simulation..
  8. yubaraj
    Oct 22, 2011
    6
    Yes i know that i need the simple rectification circuit but the ac voltage may not be constant and how can i get the constant dc voltage from variable ac source i.e Ac can vary from 110 to 240 volts.
  9. chrisw1990
    Oct 22, 2011
    543
    41
    what is the purpose of this adapter?
  10. BillB3857
    Feb 28, 2009
    2,402
    348
    I must repeat post #3. Very common approach to solving your problem.
    yubaraj likes this.
  11. yubaraj
    Oct 22, 2011
    6
    My purpose is just to design the adaptor in the matlab simulink. I got the result at the constant ac source(220V AC) but i don't know how can i get the constant Dc voltage in the variable ac source from 110v to 240v
  12. yubaraj
    Oct 22, 2011
    6
    Actually this is not the school lab project. If you know please help me to design the circuit using matlab simulink. I have no idea to get constant dc voltage for a variable ac input source.
  13. chrisw1990
    Oct 22, 2011
    543
    41
    look into switched mode power supplies (as someone mentioned earlier post #3)
    thats your best bet. then all you need is a little transformer and rectifying circuit, switched mode power supplies are very good, i have just designed one for a 3.3V 4A supply, but its input current at 24VDC is only 400mA (Thereabouts)therefore it would be a cheap and easy matter to create the rectifying circuit for it as low current is a lot easier!
    yubaraj likes this.
  14. BillB3857
    Feb 28, 2009
    2,402
    348
  15. chrisw1990
    Oct 22, 2011
    543
    41
    BillB3857, not sure here, if he just wants to simulate it?
  16. BillB3857
    Feb 28, 2009
    2,402
    348
    Plug this into Google (without the quotes) and look at the first hit.. "matlab simulinik smps simulation" It takes you to a pdf document with a lot of simulation information, graphs, etc.
  17. yubaraj
    Oct 22, 2011
    6
    Thank you for all the friends who support me. Finally i did the project.
  18. yubaraj
    Oct 22, 2011
    6
    Please check My project regarding the AC adaptor. If any problem please inform me. How to design the circuit in the PCB?
  19. mixed_signal
    Dec 5, 2009
    22
    Looks about right to me on quick inspection... You should check the waveforms at the AC input, output of the diode bridge, the gate of the switching FET the output. Could you post some of those?
    In general, if it works over a range of input AC voltages and load currents then it's regulating, at least.
    By way of free advice... It's always important to "back up" your simulation results with hand calculations. If the two are inconsistent then either your understanding or the circuit are incorrect in some way. Don't rely on only simulation since you may easily miss some conditions that cause trouble, e.g. instability. SMPS have a number of potential problem areas. Also, your Simulink models may be quite ideal (not sure?), so frequency response or voltage drops may be unrealistic. You might want to consider using a SPICE simulator (e.g. PSpice, LTSpice, ngspice, etc.).
    Cheers.
    yubaraj likes this.
