Ac input, frequency, and capacitors size suggestions?
Discussion in 'The Projects Forum' started by soeury0914, Oct 21, 2010.
  1. soeury0914
    Oct 21, 2010
    How many ac volts should I use for for my input? What is a good frequency to use? What size capacitors do you suggest? Project must have no distortion. I plan on using 3 BJT NPN. My first two stages will be Common Emmiters and my final stage will be a Common Collector. Pleeeaase help.
  2. soeury0914
    Oct 21, 2010
    Forgot to mention that it has to have a gain of 300
  3. marshallf3
    Jul 26, 2010
    2,358
    201
    Be nice if you let on what you were trying to build and included a schematic of what you've got so far.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    When designing an amplifier, the input determines how it is built.
    Most are in the audio range of 20Hz-20kHz.
    If you are working with RF, things change quite a bit.
    Need a schematic of what you've got so far, what the power supply is, what the output load will be, and the anticipated range of input frequency, level, and impedance, etc.
