ac induction (I think) motor question
Discussion in 'General Electronics Chat' started by Anthony J Brock, Mar 1, 2016.
  1. Anthony J Brock
    Oct 2, 2015
    11
    Hey everyone sorry if this has been discussed beforehand, I did have a quick look. I have an ac motor (induction I think) I salvaged just wanted to know... If I rewind the copper winding will that help increase torque ? Sorry if it is a dumb question very new to this stuff with only basic knowledge
    I have attached a photo of the motor
  2. ISB123
    May 21, 2014
    1,240
    531
    Gear it down, increase voltage. Don't play with windings since there is a high potential to mess it up. Larger the diameter of rotor the more torque it produces.
  3. Anthony J Brock
    Oct 2, 2015
    11
    Ok thanks do i increase voltage with transformer? I have a couple of microwave transformers right now it's running on mains so I assume that's 240v
  4. ISB123
    May 21, 2014
    1,240
    531
    You probably won't be able to increase the voltage.You could maybe increase the voltage by 20% without damaging the motor. Try gearing it down.
  5. Anthony J Brock
    Oct 2, 2015
    11
    Ok cheers ill see what I can find in the way of gears. Just out of curiosity is it possible by rewinding
  6. crutschow
    Mar 14, 2008
    13,478
    3,365
    Motors are normally wound for maximum torque and power.
    It's unlikely you could improve on that.
  7. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,506
    That is a small simple shaded pole motor and the mass of iron in the motor will not allow much more current without saturation of the core.
    Max.
  8. Anthony J Brock
    Oct 2, 2015
    11
    Thankyou everyone for the advice.
  9. recklessrog
    Member
    May 23, 2013
    346
    102
    You say you have transformers from microwave ovens?? Please Please don't play around with these, They can supply in the region of 2 kV at very high current that will KILL YOU instantly if you come into contact with it.
    If you were to connect it to your motor you will fry it and possibly have a fire.
    You need proper training to work with high voltage equipment, learning by mistakes is not an option as usually the first one is FATAL.
    Please do take this warning very seriously.
  10. Anthony J Brock
    Oct 2, 2015
    11
    Yes I am aware of this thankyou for your concern I am always very careful and take every precaution. some have been rewound for different projects I'm new but I do understand the dangers of playing with electricity but thankyou for the reminder
    recklessrog likes this.
