AC Induction and three phase power
Discussion in 'Physics' started by zebra1707, Nov 9, 2010.
  1. zebra1707
    Nov 9, 2010
    Hi there
    I have asked to explore the advantage of a three-phase power supply in an induction motor. How do these obtain 415 V inputs?
    Breaking it down further to:
    * Explaining how a three-phase motor achieves maximum torque three times
    in the cycle of its rotor.
    * Explaining (briefly) how this leads to higher power than is possible
    for a single phase motor with a voltage supply of 240V.
    Some guidance would be greatly appreciated.
    Cheers
  2. kokkie_d
    Jan 12, 2009
    72
    Hi ,
    I am not entirly sure on the question your asking:
    3 phase of 240 volt add them together taking in account the shift of 120 degrees per phase.
    The stator generates a torque based on magnitude and frequency of the suppleid voltage. The voltage generates and magetic field which induces a magnetic field in the rotor which will try to align with the field in the stator. The combined phases of the voltage generate 1 torque.
    The higher power is possible due to efficiency of the motor.
  3. zebra1707
    Nov 9, 2010
    Thank you for the reply. My apologies for the late post. I think that I have posted this question in the wrong area of the forum.
    You have helped me greatly.
    Cheers
