iam just a hobbyist concerning electricity,my question is if ac current
represents two opposite polarities alternating back and forth between
two terminals or contacts (from a generator)which represents a potential difference (voltage)then is the hot wire that comes into a house actually
a cable with two wires inside of it,always at opposite polarities ?or is this
just one wire that pulsates current back and forth?
and lets pretend this is a ac circuit with no earth ground,would the neutral
wire represent the ground point after the current passed through a node
and back to the generator?
and if this ground point is then grounded to earth then does the need for
this neutral wire to be reconnected back to the generator necessary?
why?,because if you grab a bare hot wire and you touch the earth ground in any way you complete a circuit,what does that have to do with
a ground point wire being attached back to the power source
