AC Function Generator?
Discussion in 'The Projects Forum' started by robotkid249, Apr 5, 2009.
  1. robotkid249
    Mar 18, 2009
    24
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    With only a single DC voltage for power, the outputs will always be DC. You would need an additional op amp stage plus a negative DC voltage to produce an AC waveform.
  3. BillB3857
    Feb 28, 2009
    2,402
    348
    Looking at the schematic, it looks like they use a "Virtual Ground" which is the output of a 50% voltage divider feeding a non-inverting voltage follower. If the "Virtual Ground" is used as the reference for the output, then A/C would be apparent, if not really true.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    Of course the square-wave, triangle-wave and sine-wave outputs are AC.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Just be aware, no real power there, but good for electronics tests and experiments.
