AC DC Power supply
Discussion in 'The Projects Forum' started by uriahsky, Nov 13, 2009.
Thread Status:
Not open for further replies.
  1. uriahsky
    Thread Starter Active Member
    Apr 27, 2009
    42
    I need to power a Bill Changer acceptor. This is just the part the accepts the bills. It requires +5VDC, +12VDC, -12VDC AND 6VAC. These voltages all have the same single ground wire. How do I recreate this on my bench? I can do the DC with my bench power supply and I have a separate AC power supply but how do I get them together so that I can power up these acceptor? I am a little confused on this one.
    Russ
  2. jamesd168
    Nov 8, 2014
    21
  3. crutschow
    Mar 14, 2008
    13,475
    3,361
    How many voltages can you generate at once?
  4. #12
    Nov 30, 2010
    16,665
    7,312
    How well can you read the date of the original post?
    RamaD likes this.
  5. jamesd168
    Nov 8, 2014
    21
    you can get two adjustable outputs, each at 0-30V; and there is a fixed third one at 5V. total three. that's why I say you can use another power supply to get 6V, or use the +12V and use a voltage divider to bring it down to +6V.
  6. mcgyvr
    Oct 15, 2009
    4,787
    973
    Clearly not a skill of jamesd168 :p
Thread Status:
