AC-DC converter
Discussion in 'General Electronics Chat' started by praondevou, Jul 30, 2011.
  1. praondevou
    Thread Starter AAC Fanatic!
    Jul 9, 2011
    2,936
    489
    I'm looking for a tiny AC-DC converter 120VAC to 5VDC. It doesn't have to have more than 50mA output current.
    I found this http://www.recom-international.com/pdf/Powerline-AC-DC/RAC01_02-SC.pdf on Digikey, but $14 is too expensive. There are some which are not isolated for $6, but I wanted them to be isolated.
    main thing here is they have to be CHEAP.
    Has anyone had this problem and found something? I don't want to build one by myself because it's going to be more expensive (component count).
  2. KJ6EAD
    Apr 30, 2011
    1,426
    363
  3. praondevou
    Jul 9, 2011
    2,936
    489
  4. iONic
    Nov 16, 2007
    1,422
    68
    They don't leave much room for spare change in there so the case dimensions are pretty much what you have inside.
  5. praondevou
    Jul 9, 2011
    2,936
    489
    Well, then it's too big... should a quarter of this at most.
  6. iONic
    Nov 16, 2007
    1,422
    68
    I think in this situation, money talks! 120VAC to 5VDC is not easy.
    It can be done without isolation, but I am not going to venture here.
  7. praondevou
    Jul 9, 2011
    2,936
    489
    Yes, for sure, and for a few mA it's not difficult. But I need them to be isolated.
  8. iONic
    Nov 16, 2007
    1,422
    68
  9. praondevou
    Jul 9, 2011
    2,936
    489
    I've seen it before and it made me smile. :D
    Too big with a 60Hz transformer and I guess more expensive than the off-the shelf encapsulated devices.
    EDIT: I found one , it's the BP5710 from ROHM, but 12V and $12, still too expensive
  10. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Buy thousands, they'll be much cheaper.
  11. Kermit2
    Feb 5, 2010
    3,845
    963
    How are you going to satisfy your polar opposite requirement?
    If one with a transformer is to big, you need a switching supply, if they are too expensive, then you need a non isolated supply, if you must have isolated then you are back to the transformer type.
  12. ErnieM
    Apr 24, 2011
    7,434
    1,625
  13. praondevou
    Jul 9, 2011
    2,936
    489
    :D Would you mind giving me loan for that?
    Problem is the 60Hz transformer, they are too big. They sell 5V wall chargers for $2, new. That means they could produce such converters. It's all a question of quantity. What I'm looking for is simply not being mass produced, that seems to be the problem...:)
    It's non-isolated, there is also one for $6,60, the BP5034D5, also non-isolated.
    Thanks for the input , guys.
  14. praondevou
    Jul 9, 2011
    2,936
    489
    I think I finally found the transformer isolated solution. It has to be CHEAP so I opened one of these chinese USB chargers which you can get for $1.50 on ebay.
    It's some kind of a super-simple smps, I'm curious to find out how it works. The secondary part certainly can be made smaller. They also will need a voltage regulator, since the output voltage can vary quite a bit. (+-0.5V)
