AC/DC ADAPTER and Battery
Discussion in 'General Electronics Chat' started by superway, Sep 26, 2013.
  1. superway
    Thread Starter Active Member
    Oct 19, 2009
    128
    I would like to ask a question.
    I have AC/DC adapter Class 2 Transformer 12Vdc 1000mA, and a battery 12V 4.5Ah. Can I connect them in parallel to apply 12vdc to my DUT or UUT? If there is no AC outlet near by, so I can use battery to power up my DUT, If the AC outlet isr near by, so I can power up both adapter and battery. I am not sure shoud it work or not?
    If not working that way, I can install 2 circuit breakers to control battery and AC/DC adapter.
    Please help
  2. wayneh
    Sep 9, 2010
    12,389
    3,245
    Are you hoping to charge the battery with the transformer? Does your load require a regulated voltage?
    The simple way to OR power supplies together is to just put a diode on each one to prevent reverse current. But diodes reduce voltage and waste a bit of power as a result.
    The wall wart likely has a bridge rectifier internally and would not require an additional diode - you'd just need one on the battery. That would prevent charging.
  3. superway
    Oct 19, 2009
    128
    My Device Under test is drawn about 450mA when turning on. I don't think the wall wart is a good device for recharge battery, and it has very small wire( Awg#22) on output side, I rule out the charging. So can put a 1N4001 in series with postive cable on battery?
  4. Brownout
    Jan 10, 2012
    2,375
    998
    An unregulated 12v wall wart can output nearly 17v. Make sure your device can tolerate the maximum output from your transformer. Otherwise, use a voltage regulator.
  5. superway
    Oct 19, 2009
    128
    When I used wall wart to power up 1 unit, the inrush current goes up to 1.1Adc about 3 sec., then drops down to 200mA. If I applied 2 units at the same time, the inrush current will be double while my wall wart is rated only 1000mA. Can it handle over current in 3 seconds?
  6. Brownout
    Jan 10, 2012
    2,375
    998
    3 seconds is a pretty long time. I assume you don't have any specs for you adapter, and so there is no way to know.
  7. wayneh
    Sep 9, 2010
    12,389
    3,245
    You can get away with it but it's not good practice.
  8. superway
    Oct 19, 2009
    128
    Yes, 3 seconds is a pretty long time to load about 2 amps, but after that the current drops down to 400mA. It is not good practice, but I just want to turn 2 units on for demo.
  9. wayneh
    Sep 9, 2010
    12,389
    3,245
    A proper adapter would cost very little and remove all concern.
  10. Brownout
    Jan 10, 2012
    2,375
    998
    Its a bad idea, but if you already made up your mind you don't need my advice. Take care.
  11. #12
    Nov 30, 2010
    16,704
    7,351
    I don't think the adapter will survive 100% overload (for 3 seconds) more than a few times. Try it. If it smokes, you will know you were wrong and end up buying the right adapter.
