ac Current limiter
whiteggs
Joined Feb 15, 2010
14
Looking for a low cost way to current limit a 120v AC outlet to 200W. So, devices won't work if total power usage exceeds ~1.5A.
praondevou
Joined Jul 9, 2011
2,942
If maximum current is exceeded what is the limiter supposed to do? Lower the voltage, cut off the current or cut off only power to one device? If cutoff, how do you reset it?
wayneh
Joined Sep 9, 2010
17,498
You might find a power strip in which you can change the value of the embedded circuit breaker. They're usually 15A, so I'm not sure, just throwing out an idea.
