Now, the current clamp comprises of a split ferrite ring which a wire coil is wound in both halves forming the secondary winding like a transformer. If the "clamp" goes over the conductor and its able to measure the current proportionally.
If the current clamp is used to read a magnitude of a sinusoidal current, it should be theoretically be used to inject current into a conductor? Right?
Supposing, I use a frequency generator to provide signal to the coil, would conductor produce emf?
