AC Coupling
Discussion in 'General Electronics Chat' started by Terrozer, Feb 2, 2011.
  1. Terrozer
    Feb 2, 2011
    Is there a way to perform AC coupling without the use of a capacitor?
    Thanks in advance!
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Sure. Use a transformer.
    Welcome to AAC!
    The more information you give, the more you get back.
  3. Terrozer
    Feb 2, 2011
    Thanks!! :)
    Must the number of turns on each side be equal to use a transformer for ac coupling purposes please?
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
  5. Adjuster
    Dec 26, 2010
    2,147
    300
    The ratio need not be 1:1 in every case. One advantage of transformer coupling is the possibility of using different ratios for impedance matching.
    This may be done to obtain optimum gain, where stages with different output and input impedances are coupled together.
