AC Coupled Gate Drive Problem
BlackMelon
Joined Mar 19, 2015
168
Here I attached a research paper file. On page 28, the two equations at the end yield the first equation on page 29 (Let me name it "equation A"). I am curious in the equation A. It states that there is dc voltage across the coupling capacitor proportional to the duty cycle. But if you look at my scratch paper, I use the superposition theory. Considering DC part first, the DC component across the coupling capacitor would be Vdrv/2 no matter how high is the duty cycle. (Because the impedance of the coupling capacitor is infinite when it is connected to a DC voltage source)
Am I wrong? If so, why it can't be proved in my way?
Thank you
BlackMelon
34,469
Below is the LTspice simulation of an RC test circuit for a 10Vpp signal with a duty cycle of 20% for the first half of the trace and 80% for the last half.
As can be seen, the voltage across the capacitor (bottom trace) is about 2V for the 20% duty cycle and 8V for the 80% duty-cycle, as the research paper states
See if you can determine why your reasoning is not correct.
BlackMelon
Joined Mar 19, 2015
168
Could you please tell me about the code "PULSE (0 10 0 0 0 1us 5us 30)". I want to know about V1 and V2 each too, so I might have some more information to detect my fault.
Thank You
BlackMelon
