Ac coupled Amplifier question
Discussion in 'Homework Help' started by Panterulez, Apr 8, 2009.
  1. Panterulez
    Mar 25, 2009
    7
    According to my notes, it is stated the CC amplifier, an emitter-follower gives low output resistance and buffers the high gain stage from the relatively load resistance. I just don't seem to understand what this exactly means ? Can anyone enlighten me
  2. The Electrician
    Oct 9, 2007
    2,301
    339
    The load is 250 Ω. If it had been connected to the collector of the C-E amplifier (through C5), then the effective collector load resistance would have been 4700 Ω in parallel with 250 Ω, and the gain of the C-E stage would have been drastically reduced.
    The emitter follower has a low output resistance to drive the low resistance load, and a high input impedance to avoid loading the C-E stage.
  3. jasperthecat
    Member
    Mar 26, 2009
    20
    You could look at the theory here
    http://www.allaboutcircuits.com/vol_3/chpt_4/index.html
    or Wikipedia to better understand the various transistor configurations of
    Common Emitter, Common Base & Common collector.
    A little cheat sheet on BJT configurations helps
    CE Zin =medium Zout =medium Gain >>1
    CC Zin = Hi Zout = Lo Gain <1
    CB Zin = Lo Zout = Medium Gain >>1
    Hope this helps
