AC couple pin to GND?
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Mar 23, 2015.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
  2. Reloadron
    Jan 15, 2015
    1,043
    268
    No, here is what our friends at NI say:
    If we have an AC signal riding on a DC component level using a cap in the line will block the DC component. Here is the NI pdf on the subject.
    Ron
  3. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    @Reloadron yes the link I got what ac & dc coupling mean.
    But in my circuit I have to ac couple a pin to GND. Does that mean that I have to connect a capacitor between pin & gnd like a decoupling capacitor.
  4. #12
    Nov 30, 2010
    16,665
    7,310
    That's what it sounds like, but "in my circuit" makes this look like you sent us to a reference that has nothing to do with your circuit. How are we supposed to guess what YOUR circuit needs?
  5. Reloadron
    Jan 15, 2015
    1,043
    268
    Anytime since a capacitor passes AC and blocks DC you connect AC to to a capacitor that is going to a ground you have effectively shorted your AC signal to ground and thus this makes no sense. DC power pins use a decoupling capacitor to ground but coupling an AC signal to ground makes no sense. Would really need to see a schematic or drawing of what you are talking about.
    Ron
  6. Ramussons
    May 3, 2013
    562
    92
    The term "ac couple" in this context is ambiguous. The term "couple" is used when we want to pass on signals for further use - amplifying, filtering, etc. "bypass" or "decouple" is the term used when "ground" comes in.
    You need to show a schematic or a explanation for us to infer what actually you mean in this particular case.
    If we do away with the terminology, "Yes" is the answer to your question.
