AC Compressors
Discussion in 'General Electronics Chat' started by R!f@@, May 10, 2012.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,793
    771
    Like to know why we cannot use a 60Hz one.
    Our mains are at 50Hz.
  2. #12
    Nov 30, 2010
    16,705
    7,358
    Lower drive frequency causes the magnetic field to saturate. Smoke escapes.
  3. strantor
    Oct 3, 2010
    4,302
    1,989
    Could you make it work by changing the capacitor? or is the problem in the magnetics?
  4. shortbus
    Sep 30, 2009
    4,098
    1,697
    Not an ideal situation but it will work, within limits. A lot has to do with the voltage AND the Hz, as in the V/f ratio. For a good read on the matter this short link explains it real well - http://www.eng-tips.com/faqs.cfm?fid=1224
    strantor likes this.
  5. strantor
    Oct 3, 2010
    4,302
    1,989
    Good read indeed. Thanks.
  6. R!f@@
    Apr 2, 2009
    8,793
    771
    I want to run a 110V 60Hz compressor at 220V 50Hz.
    What are my options ?
  7. #12
    Nov 30, 2010
    16,705
    7,358
    Apparently the motor will work if you reduce the voltage applied by 50/60 times the nameplate voltage rating.
    If it is really rated at 110 volts, you will have to give it 92 volts at 50 Hz.
    It will not produce the power it was designed for at 60Hz and 110 volts.
    Right?
  8. R!f@@
    Apr 2, 2009
    8,793
    771
    Are u sure ?
  9. #12
    Nov 30, 2010
    16,705
    7,358
    Read the link in post#4
    I believe he is sure.
  10. strantor
    Oct 3, 2010
    4,302
    1,989
    What I would say after reading that writeup is that if you give it 92 volts at 50 Hz, it would have the best chance at working. Even if you gave it 92V, you still have the following to worry about (excerpts):
  11. debe
    Sep 21, 2010
    955
    185
    Some of the cheep compressors have barely bigenough motors on them & burn out easily. So running a 60HZ on 50 HZ may be not wise.
