Your reactive power values are correct. Normally to get apparent powers you use the power triangle. It's hopefully reasonably obvious (after a little thought) that, in the case of each parallel branch element, either the real or reactive power is zero - so the apparent power reduces to a trivial value in each case.
As this is directly related to the TS's topic, I won't split it off as a hijack.
There is no need to put forth the effort to make your text look like a rainbow, particularly when it makes it difficult to read and is annoying to most readers, particularly engineers and other techies who, as a rule, strongly favor function over form.
As this is Homework Help, you need to put forth some effort to solve the problem you are asking.
