what is the formula to find power factor in an AC circuitry? thanks for the help
J Thread Starter Joess7 Joined May 12, 2009 3 May 16, 2009 #1 what is the formula to find power factor in an AC circuitry? thanks for the help
hgmjr Joined Jan 28, 2005 9,027 May 16, 2009 #2 Here is a link to the section on power factor located in the AAC ebook. You will find the equation there. hgmjr
S skibum9x99 Joined May 22, 2009 2 May 22, 2009 #4 Instantaneous or Average Power Factor? Instantaneous = W (E*I)*(COS of Phase Angle Difference between the Voltage and Amperage) / VA....or Average over time: kWh / kVAh. If kVAh are not available; √ kWh2 + kVARh2 .
S skibum9x99 Joined May 22, 2009 2 May 22, 2009 #5 My mistake! The previous equation will give you kVAh, then use kVAh/kWh for average PF. Sorry!
