AC Circuit Problem
Discussion in 'Homework Help' started by mhanssler, Jul 7, 2011.
  1. mhanssler
    Jul 7, 2011
    I cannot seem to wrap my head around this problem...
    If the voltage across and the current through the series combination of a resistance and an unknown energy-storage (presumably an inductor) element are:
    v=200cos(10^2t + 60°)
    i=5.547cos(10^2t + 93.96°)
    then find the resistance as well as the unknown element
    Any help would be much appreciated.
  2. tubelite
    Jul 20, 2010
    6
    a hint: you could use phasors/polar coordinates to solve this problem.
  3. mhanssler
    Jul 7, 2011
    Yeah. I am just learning about them now. I have been stuck on this problem for awhile....
    So, I have two unknowns (R and L)
    I know that Z=R+jwL
    I know that V/I=Z
    I just cannot seem to come up with two equations that will allow me to solve this...
    any stronger hints that you can help with??
  4. mhanssler
    Jul 7, 2011
    also, I know:
    This is a simple voltage divider circuit....
    hence
    Vr= R/(r+jwL)Vs where Vs is 200arg(60deg)
    If I found Vr I could use that to find R by dividing by the current i. This is true because the circuit is in series...
    But again... I need values for R and L so I am thinking this is the wrong way to go...
  5. blah2222
    May 3, 2010
    565
    33
    You were on the right track with Z = V/I. If you perform the phasor division you can obtain Z, then convert that into rectangular complex to find the values that you are looking for.
    Phasor: Z = Zmag<(argZ)
    Rectangular: Z = R + jwL
  6. lazukan
    Mar 29, 2011
    5
    Convert it to the phasor and Use R= V/ I and make some algebra in complex numbers , its pretty easy
    Regards
    Lazukan
