Hello all. First off, I would like to thank you in advance for any help you are able to offer, I've done basic DC circuit design when given standard book problems but AC circuit design with real world components is what I need here.
In short: I have a pneumatic system that I need to control with a simple electrical system. Essentially, I have a 2-way air cylinder that I need to actuate using a 4-way solenoid (essentially acts as a switch). I need it to turn on and off when a distance sensor sees objects (sees object 1, on, sees object 2, off, sees object 3, on, etc., etc.). This also needs to be delayed a second or two, so I would need to know how to do that.
The use is to automate a piece of equipment that will actuate shortly after it sees the next object coming. (it sees the object as it falls onto the equipment, then actuates)
I hope this was a thorough enough explanation and again, I appreciate any help and light you can shed on this type of circuit. Thanks!
