AC (+) and (-) finder circuit
Discussion in 'General Electronics Chat' started by Eplanet, Jun 22, 2009.
  1. Eplanet
    Thread Starter Active Member
    Oct 25, 2007
    42
    hello all
    can you help me for making a circuit for finding + and - in AC main power.
    thanks
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    Hi Eplanet,
    Mains power is Alternating Current. It does not have + and - because its polarity keeps alternating. Direct Current (like from a battery) has + and -.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    In a modern system with a ground wire run separately, a voltmeter can find the AC hot, as it will be the one wire that is: Inside black or red insulation, and is the only wire to show line voltage to both AC common and ground.
  4. Eplanet
    Oct 25, 2007
    42
    i see somewhere that not exist any standard colors for wire but i use standard ways and occurs very bad event i don't want to use DMM. i need very simple circuit.
    i know there is no + and - for AC i mean phase and ground. i need electronic circuit for indicating phase and ground for exp with LED or buzzer. this is tool for repairing electrical device.
    thanks
  5. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    connect a ne22 neon tube ( think that is the number ) with a high reisitance 5 meg ( series ). ground one end, the tub will light when the other end is connected to the hot wire. you may need to run ohm's law to get the value of the resistor right. these testers come all made up, buy one? ( the neon tube is a very low current device ) for higher current use a lamp in a socket with pig tails, also a very standard item.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    As long as everything is insulated, that will find the AC line. The "usual" resistor for a NE2 is 270K - 470K. 2M will be very dim.
