AC and DC ground
Discussion in 'General Electronics Chat' started by kai88, May 7, 2010.
  1. kai88
    Jan 26, 2010
    10
    Can we ground AC and DC at the same ground stud?(in what condition?)
  2. VoodooMojo
    Nov 28, 2009
    503
    53
    Never confuse Neutral for Ground
    Always verify that Neutrals and Phase wires (white and black respectfully) have not been reversed somewhere. Never forget "black to brass, white to bright".
    Yes, they can share the same ground attach.
    Should they or not will always be a debate.
    Especially for those dealing with marine applications.
  3. retched
    Dec 5, 2009
    5,201
    313
    Think about AC to DC converters. Where do you think the ground goes?
    The DC circuit goes right into the AC neutral or ground (which connect in a breaker box)
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It's important to not confuse "earth ground" with "neutral".
    Neutral is the power return for AC.
    Earth ground is protective; connected to the chassis/enclosure.
    Neutral carries all of the return current that the "hot" line/lines supply.
    Earth ground should carry no current at all.
    In the States (USA), the earth Ground bus is connected to the Neutral bus inside the electrical service panel for safety purposes. This is the ONLY place in the system that they are connected together. After the wiring exits the service panel, Neutral and Ground are separate; any current above a few mA on Ground is considered an electrical fault.
    This is somewhat confusing, because in most schematics you see posted here, the ground is used as a power return. In simple electronic schematics, ground is used as the 0v reference point. In most cases, it is also connected to earth ground. However, the earth ground does not carry any current; but it does establish the 0v reference point.
