ac analysis emitter follower
Discussion in 'General Electronics Chat' started by soedar, Apr 7, 2011.
  1. soedar
    Apr 7, 2011
    I'm confused :eek:. How did they get to the following equation for the output impedance of an emitter follower? It's on page 270 of "Electronic devices and circuit theory", Robert L.Boylestad and Louis Nashelsky, 9th edition.
    Equation 5.64: Zo=ro//RE//(βre/(β+1))
    I would only get to Zo=ro//RE//βre
    I have attached the ac equivalent circuit.
  2. saqib altaf
    Apr 7, 2011
    Dear u have written the wrong value of Z0 its like
    Zo=ro//RE//Bre/(B+1)
    1 can be ignored as B is a very high value so
    Zo=ro//RE//re
    as ro is very greater than re than we hav
    Zo=RE//re
    for example ro//re if ro=2ok ohm and re=12 ohmthan re//ro is nearly =re thats y we ignore ro.so our resultant ro is
    Z=RE//re
  3. soedar
    Apr 7, 2011
    Hello Saqib,
    I have attached a scan of the page. Check it out...
  4. soedar
    Apr 7, 2011
    The question is: How did they get to equation 5.64?
    In theory to establish the output impedance Zo, the Vi should be set to zero, the base current Ib will then be zero. Further more the current source should be replaced by an open circuit.
    So if I now look into the circuit from the output side, after doing all the things described above, I would get Zo=ro//RE//βre.
    But they get Zo=ro//RE//(βre/(β+1)). How did they get the βre/(β+1)???
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    Ib will not gonna to be 0A
    Because in general we can calculate output impedance by applying a voltage source Vin to the output node.
    Zo = Vin/Iin
    So I hope that now is is clear to see that
    Ib = Vin/(βre+RB)
    And also remember that Ie = Ib + Ic = (β+1)*Ib
    Zo = Vin/Iin
    Iin = Iro+IRe + Ie
