AC adapter to battery switch transient
electrophile
Joined Aug 30, 2013
167
Here is a schematic that switches to a battery source when the AC adapter dies out. It works but there is a drop transient which is about 50% of the output voltage. Any suggestions on how this can be reduced or better yet eliminated? Also attached is the LTSpice file.
AlbertHall
Joined Jun 4, 2014
12,346
The adaptor voltage has to get very low before the MOSFET will turn on (up to 3V below the battery voltage). If the adaptor voltage is greater than the battery voltage then do away with the MOSFET and connect the anode of D2 to the battery.
electrophile
Joined Aug 30, 2013
167
Unfortunately the battery and AC adapter are more or less the same voltage since when the power goes out, the battery takes over.
If I were to eliminate the P-MOSFET, both the AC adapter and the battery would share the load current and this is not something that is feasible since when the AC adapter is present the battery is being charged.
AlbertHall
Joined Jun 4, 2014
12,346
You might have a look at the LTC4412 or similar.
Or, if you have access to the internals of the adaptor and it is regulated, then you could use the fall of voltage before the regulator and use that to trigger the switchover. This way you can switch to battery operation before the regulator output has begun to fall.
johnmariow
Joined May 4, 2016
19
I agree that the MOSFET may be creating the problem. To learn more about this, replace the adaptor with a square wave generator in LTSPICE. Then observe the square wave on the gate of the MOSFET and the square wave on the anode of D2. You will probably observe a time delay between the falling edge of the square wave from the square wave generator and the rising edge of the square wave at the anode of the diode. I suspect the the width of this time delay will be equal to the width of the transient you are observing.
electrophile
Joined Aug 30, 2013
167
Interesting but opening up the regulator would be too much of a hassle and wouldn't be feasible. I've seen the LTC4412 and though its available in my part of the world, its fairly expensive at an equivalent of about $10. I was thinking more on this and instead of grounding the P-MOSFET gate directly, I added a PNP transistor there and switched that using the AC adapter voltage. This seems to get rid of the transient when the switching happens. I also see a voltage drop of about 70mV on the output.
johnmariow
Joined May 4, 2016
19
johnmariow
Joined May 4, 2016
19
I was talking about doing it in the LTSPICE circuit simulator. Not on the actual circuit. The transistor would react faster than the MOSFET; but you still would have a race condition. The transient will be less, but I think it will still exist.
electrophile
Joined Aug 30, 2013
167
Yeah I was replying to Albert and your reply came right then and it looked like I replied to your message :) I'll try the square wave generator simulation. Will keep you posted.
AlbertHall
Joined Jun 4, 2014
12,346
Is this simulated or real world? The real world adaptor will have an output capacitor which will mean its output voltage will fall slowly when mains power is removed and that is going to be difficult to get around unless you add a very big capacitor on the circuit output to maintain the load voltage until the adaptor voltage has fallen far enough to turn the MOSFET on.
The circuit with the transistor pulls the gate to ground but it doesn't pull it up so because of the gate capacitance the MOSFET may never be turned off. That might be why the transient disappeared. There should be a resistor from gate to source.
grahamed
Joined Jul 23, 2012
100
Hi
You might like to consider the use of a "perfect diode" in place the current switch and Schottky arrangement.
The Schottky may only drop 1/2V or so but that is 10% of your battery wasted.
electrophile
Joined Aug 30, 2013
167
This will be eventually implemented in the real world. I see what you mean. I placed a 1k resistor there and now I see the 2.6V transient again.
@johnmariow I simulated it with the square wave instead of the adapter and you are right, the width of the time delay is the transient width as well.
So how do I build this without the LTC chip?
electrophile
Joined Aug 30, 2013
167
Hi
I'm not sure I understand this schematic. Could you please elaborate? Where would my two inputs go?
AlbertHall
Joined Jun 4, 2014
12,346
If you cannot be sure that the adaptor voltage will always be greater than the battery voltage then I don't see how.
Another wild thought: Use a higher voltage adaptor with a separate regulator in your circuit to get the correct voltage. That way you can implement the method I described earlier.
hp1729
Joined Nov 23, 2015
2,304
A capacitor on the output? Maybe 100 uF or so depending on the current being drawn.
grahamed
Joined Jul 23, 2012
100
The FET connects exactly where it is now, the diode is removed.
The FET is controlled by the BJTs which switch it on as required to act as a diode.
Due to the common base voltage they are controlled by the emitter voltages.
If the input-side BJT has the higher emitter voltage it turns on, the output-side BJT turns off which then allows the FET to turn on.
The simulation should demonstrate all this.
grahamed
Joined Jul 23, 2012
100
if the .asc shows a diode across the FET (I can't see it at the moment) please ignore it. It doesn't do anything. I included it because the FETs I had to hand had an intrinsic diode but the model did not include one.
AlbertHall
Joined Jun 4, 2014
12,346
But does this switch depending on whether adaptor or battery has the highest voltage, and given that that cannot be guaranteed in this case then, with a fully charged battery and the mains voltage on the low side, it will operate from the battery despite mains power being available?
grahamed
Joined Jul 23, 2012
100
All diode switches operate on the basis of the higher voltage. This is no different just a better diode.
If switching is required then a further BJT CE// with the input BJT will do it.
Tonyr1084
Joined Sep 24, 2015
7,899
What about using an Op-Amp to compare the two voltages? The moment the adaptor drops below the battery voltage the Op-Amp can trigger a switch. Even if the battery voltage isn't at its peak charge, the Op-Amp won't switch out until that threshold is crossed. Wire the amp as a comparator. That way its output can control a MOSFET or two, shutting one supply off and switching the other on. I'm sure a few milliseconds of crossover wouldn't hurt anything if both supplies are giving a push for that short duration. The switch that cuts out the PS can be held high for a few mS via a capacitor. Meanwhile the other MOSFET can switch the battery into the circuit before the first cuts out.
Am I wrong?
