Was wondering.... I have a circuit board powered by a 6V/200mA AC adapter. Would substituting an adapter of the exact same voltage but double or triple the current potential (400-600mA), possibly damage the circuit board?
Not so long as the polarity of the output plug matches - and fits.Was wondering.... I have a circuit board powered by a 6V/200mA AC adapter. Would substituting an adapter of the exact same voltage but double or triple the current potential (400-600mA), possibly damage the circuit board?
Per se, no worries in theory. If you really want to be careful, check the actual output voltage under load using the two chargers. You'll have to make a judgement as to how big a difference is ok. An undersized "6 volt" charger might deliver 8 volts under no load and drop to 4 volts as it struggles. The beefier charger might deliver 6.5 to the load, possibly a significant difference.Was wondering.... I have a circuit board powered by a 6V/200mA AC adapter. Would substituting an adapter of the exact same voltage but double or triple the current potential (400-600mA), possibly damage the circuit board?
