AC 12v Synchronous Motor
Discussion in 'General Electronics Chat' started by John Berry, May 31, 2016.
  1. John Berry
    May 17, 2016
    10
    Hello I have just purchased a synchronous motor for my Christmas tree - AC 12v 50/60Hz 1-2W
    I now want to purchase a mains power adapter to plug into the tree base.
    I have tried many Webb sites but no one understands what I am wanting.
    What exactly should I type into the search bar? Should the label on the adapter read the same as the motor, ( Output 12v ac 50/60Hz 1-2W) ?
    Hope someone can help.
    Many thanks
    John :)
  2. crutschow
    Mar 14, 2008
    13,523
    3,390
    John Berry likes this.
  3. #12
    Nov 30, 2010
    16,705
    7,358
  4. John Berry
    May 17, 2016
    10
    Thank you very much :)
  5. Dodgydave
    Jun 22, 2012
    5,167
    777
  6. John Berry
    May 17, 2016
    10
    Thank you all very much for your help
    John :)
  7. John Berry
    May 17, 2016
    10
  8. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    See if you can obtain a mains bell transformer here they come just above 12vac, the voltage is not critical.
    A straight transformer is not exactly a precise component anyway.
    Max.
  9. Dodgydave
    Jun 22, 2012
    5,167
    777
    Yes, its plenty powerful.
  10. John Berry
    May 17, 2016
    10
    Just one last question please, I have noticed that on my sync motor that both the wires are black.
    Not 1 red and 1 black? Which is + and - ?
    Thanks again.. John :)
  11. Glenn Holland
    Member
    Dec 26, 2014
    361
    114
    Gee, it's only June 1St and you're already planning for Christmas???
    I thought Christmas was getting too commercialized and the holiday season is getting moved up earlier and earlier. When Christmas does finally arrive, don't forget to start planning for the 4Th Of July. In some places, fire crackers go on sale in January. :D:p:)
    John Berry and Dodgydave like this.
  12. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    There is no + &- with AC, they 'Alternate';)
    The leads are bi-polar.
    Max.
  13. Dodgydave
    Jun 22, 2012
    5,167
    777
    We don't celebrate that in UK, we do Guy Fawkes in November..:D ( dozy sod fancy trying to blow up a government building in winter :confused:)
  14. #12
    Nov 30, 2010
    16,705
    7,358
    Is it better to blow up government buildings in the summer?:confused:
    You might check with the Celts or Druids about Yule.;)
    Sinus23, John Berry and Dodgydave like this.
  15. Tonyr1084
    Sep 24, 2015
    637
    112
    DC is Direct Current - or current that is always moving in one direction - hence the need for a positive and a negative, and usually a red wire and black wire for positive and negative.
    AC is Alternating Current - or current that is constantly changing direction. There is no positive and negative in an AC motor or AC power supply. So you don't need a red and black wire; two black wires will do the job just fine.
  16. John Berry
    May 17, 2016
    10
    Thank you all very much for your help it is much appreciated
    John :)
