Absolute Value Generator vs. Full-Wave Rectifier
Discussion in 'General Electronics Chat' started by BobbyTheD, Apr 22, 2016.
  1. BobbyTheD
    Mar 10, 2016
    12
    Hi AAC -
    I'm looking at circuit 16 in Texas Instruments AN-20, http://www.ti.com/lit/an/snoa621c/snoa621c.pdf.
    The circuit uses two large capacitors at the input and, in the notes, it states that this is the difference between the circuit functioning as an "Absolute Value Generator" and a "Full-Wave Rectifier."
    Could someone explain the difference to me?
    Also, the offsets seem very large on the non-inverting inputs. I'm not sure if anyone has experience with the LM107 in contrast with the TL074 - but is it possible that modern op-amps don't require that kind of compensation?
    Thanks.
  2. #12
    Nov 30, 2010
    16,663
    7,308
    Fig. 16. Photovoltaic Cell Amplifier
    This isn't working. Please clarify.
    Yes. I was there for the LM101. Offset voltage has improved quite a bit since then.
  3. BobbyTheD
    Mar 10, 2016
    12
    Sorry, it's circuit 16 - in the table of contents... it's figure 25.
  4. #12
    Nov 30, 2010
    16,663
    7,308
    If you short out C1 then this full wave rectifier will respond to any DC level at the input. With the capacitor, it's a full wave rectifier of the AC signal. Without the capacitor it's still a full wave rectifier, but it will include any DC component in its activities.
