About zener codes
Discussion in 'The Projects Forum' started by MMH, Feb 24, 2013.
  1. MMH
    Feb 8, 2013
    143
    Hello there!! I have some zener diodes. on them it is written "2". That means it is two volts. Right?However on the packet, it is written 1.8v zener diodes. which one is true?
    Thanks in advance for your help
  2. MrChips
    Oct 2, 2009
    12,652
    3,461
    No.
    What is the full part number? Or are you saying "2" is the only marking on the diode?
  3. MMH
    Feb 8, 2013
    143
    Thanks for answering!! On one side of the diode it is printed "2" and on the other side,"B1". It looks sth like this:
    Taking the blue band to the left,(Diode original color-orange) it is written "B1". turning the diode as if it is the axle of a motor, there is written "2". Now I dont understand what that is.:confused:
  4. MrChips
    Oct 2, 2009
    12,652
    3,461
    Get a 9V battery and connect a 1kΩ resistor in series with the diode and battery.
    Measure the voltage across the diode. Reverse the diode (or battery) and measure again.
  5. #12
    Nov 30, 2010
    16,705
    7,358
    You have no right to expect the manufacturers to print reasonable information on a zener diode. Do as MrChips said to find the truth.
  6. GopherT
    Nov 23, 2012
    6,330
    4,078
    There is a good chance that it is a 12 volt zener (B12 the last digits). Several manufacturers use this protocol to indicate zener voltage (e.g. 5B6 is a 5.6volt zener and 10B is a 10 volt zener (B is at the end on all zeners over 10 volts in some manufacturer's series).
    If it is 12 volt, then you will need two 9 volt batteries in series. Likely a 5 ma current so use a 1000 to 1500 ohm resistor (1200 ohm preferred).
  7. MMH
    Feb 8, 2013
    143
    Thanks for answering!! I used a 5v usb port instead of a 9v batt. When in reverse bias, the voltage is 1.863 and in forward bias, the voltage is 0.729. So whats the Zener voltage?
  8. Meixner
    Member
    Sep 26, 2011
    116
    21
    It would be 1.8 Volts
    MMH and #12 like this.
  9. MMH
    Feb 8, 2013
    143
    Thank You very much!!!!
    But how did you find it?? Is it because in reverse bias, the voltage is 1.863??
  10. MrChips
    Oct 2, 2009
    12,652
    3,461
    When forward biased a zener behaves like a regular diode.
    Zener action occurs as avalanche breakdown when the diode is reversed biased.
  11. DickCappels
    Aug 21, 2008
    2,780
    675
    Mr. Chips rounded the measured number "1.863" to 1.8 because 5% and 10% tolerances are common and common practice is to specify a component's value with appropriate resolution.
