The question doesn't say to neglect the LED voltage which can vary from 1.5 to 4 volts depending on the colour of the LED. Thus you have to include it since Vcc is just 10V and 2V across the LED can be quite significant.i think the voltage drop of LED is neglected, as it only just need 20mA on Ic , The problem states that What voltage (Vin) does it need to produce that 20mA on Ic
1 Volt across the resistor *2 +Vbe = 2.7 VoltsHmm,
Ib_min = 200uA so if safety margin is 2*Ib_min = 400uA
Vin = Ib*Rb +Vbe = 2V+Vbe
Or
Vin = 200uA*5K + Vbe = 1.7V----> 2*1.7V = 3.4v
Thread starter | Similar threads | Forum | Replies | Date |
J | Dimmer Circuit Simulation Problem | PCB Layout , EDA & Simulations | 9 | |
Z | Problem with transistor | Homework Help | 16 | |
Transistor heating problem in slayer exciter circuit | General Electronics Chat | 2 | ||
L | Transistor problem in motion sensor circuit | General Electronics Chat | 17 | |
Transistor circuit analysis problem | Homework Help | 10 |
