When using your ohm-meter or continuity tester, impedance of the coil in your transformer does not matter. Other than initial current, the DC depends only on the resistance of the wire in the winding. From there, it depends upon how your meter works as to whether it will beep or not. What do the two windings read in ohms?
I asked that question in post #13 but you chose to continue on the thought that the inductance of the coil will cause a beep or no beep. That simply is not true.
