About Transformer ?
Discussion in 'General Electronics Chat' started by wkyong, Apr 30, 2008.
  1. wkyong
    Thread Starter Active Member
    Apr 29, 2008
    33
    If a transformer rating 240vac 50hz being supplied by a source 240vac 60hz,will it get hotter than by 240vac 50hz source?
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Not noticeably so, no. Losses from the slight increase in frequency will be negligible.
  3. mik3
    Feb 4, 2008
    4,846
    63
    You will notice a small decrease on the secondary voltage of the transformer but it wont get hotter.
    if you do it the other way round, a 60Hz transformer plugged to 50Hz, you will notice a small increase on the secondary's voltage. In this condition, when you reach its rated current you will probably burn it out.
