I was thinking the same when I asked what the important part of the signal was, he foiled that idea when he said the rise time and decay time was important - I think.Hello,
Could a sample-hold process work?
Bertus
Thank you for the comment, GopherT.If you have data stored in software, the reference and signal are all collected by PD-A, why do you want to add additional noise and uncertainty by introducing a second Photodetector that has to be calibrated vs first detector? Also, the path and cell that contain the sample are not the same. YOur single-path setup is perfect. Now, you just need the software to subtract a reference signal mm editable before it.
If your sample is causing a time delay (fluorescence or phosphorescence), then you can still use a single beam but you need to collect data with a precision time signal as a second stream of data - using that second stream of data to trigger your laser pulses.
Thank you for the comment, really. That looks nice to use the counter.That's a great description of your setup.
I think device differences and tiny delays you are trying to measure could be a challenge.
Two possible approaches.
First, have one beam and one sensor. Measure the phase difference between the signal driving the laser and the sensor signal.
Do the measurement twice, one without sample and one without sample. Delta the two.
You will need to control laser brightness. If you don't want to do that, use two beams plus two sensors and Delta the signal from the two sensors. And then swap the light path.
Alternatively, you can use the signal driving the laser to trigger a counter, and use the signal from the sensor to stop the counter.
A two laser two sensor version of this approach is also possible.
You probably need a high speed counter for this.
Thank you for the kind reply, GopherT.How are you collecting and storing your data from the detector(s)? An off-line manipulation of your data is the normal process. Identify which is a background signal and which is a "sample" signal. Subtract and move on.
by Duane Benson
by Duane Benson
by Duane Benson
