About tablet and lion battery charger
Discussion in 'General Electronics Chat' started by sony85, Mar 8, 2016.
  1. sony85
    Aug 26, 2012
    43
    TP4056-1A-Battery-Charger-Module-2.jpg I have an tablet which micro usb jack mask burnt out and i had to find other solution tocharge my tablet. Than i bought Li-on battery charger module
    Specification of the modul
    • Module Name: rechargeable lithium battery plate
    • Method: linear charge 1%
    • Charging current: 1A Adjustable (Through RPROG)
    • Charge Accuracy: 1.5%
    • Input voltage: 4.5V-5.5V
    • Full charge voltage: 4.2V
    • Charging indicator: red green full charge
    • Charging input interface: mini USB
    • Working temperature: -10 Degree to +85 Degree
    • Polarity Reversal: NOT ALLOWED
    My question is how can I make it work Charge the battery and tablet to be on at the same time ?
    Is it possible .
  2. Dodgydave
    Jun 22, 2012
    5,166
    775
    You need to solder the batt terminals to the tablet battery connection, then it will charge it up, there may not be enough current to run it at the same time,
    datasheet
    what tablet make and model is it.
  3. sony85
    Aug 26, 2012
    43
