Hello Everyone
I want to make a project, in which I want to connect a pc with a distant micro (around 200m-300m), so I want to send data form pc as ethernet then converting it again to serial to be readable by micro.
My question now is the following: Is using such converter help by distance problem?
I imagine the system to be as follows: the PC sends data in ethernet form- data flows into cable till the first 100m- the repeater or the bridge repeats signal- another 100 m- the repeater or the bridge repeats signal again- to eathernet/serial converter - to micro
Is this configuration alright? or nonsense?
