about RMS value
moh_alluzi
Joined Mar 1, 2010
hello ,
i am mechanical engineer please i just want to ask about the RMS value why i use it and when what is the benifit of use the whole things please if u have an answer
thank u all
Mike33
Joined Feb 4, 2005
349
RMS (root-mean-square) is the AVERAGE current flowing in a circuit. As you know, AC is by definition alternating, so the best we can get to a 'real number' for it is the RMS average. It's a "power average", too....
The true AC level (peak) is 1.414 times the RMS value. RMS = .707*peak.
>>>At the RMS value, the current will do as much WORK as the same level of DC voltage<<<. Hence the term 'power average'.
An example is 120VAC, RMS (U.S. line voltage)...its peak is 170VAC or so. But the average 120V will do as much work as 120 volts DC.
You get used to using it after a while :eek:)
