about power factor correction capacitor
Discussion in 'Power Electronics' started by balvendra, Aug 22, 2016.
  1. balvendra
    Sep 3, 2014
    I want to correct power factor in single phase light so what rating capacitor i should connect across supply
  2. Marley
    Member
    Apr 4, 2016
    171
    46
    Is this a fluorescent light? What does it say on the ballast inductor (choke)?
    Current? Phase angle? Power rating of the lamp?
    From these the correct value of capacitor can be calculated.
  3. tcmtech
    Nov 4, 2013
    2,115
    1,752
    Why and what type and size of light?
    What do you expect to gain from PF correction for a small load?
  4. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    The landlord insisted on having their electrician put a splashproof fitting in the bog - it was a 28W D fluorescent, I think the PFC cap was 4uF.
    The cowboy contractor was a complete dumb*** and fitted the wrong ballast, so the light never worked properly and didn't last long.
    Instead of calling in their contractor to **** it up even more - I ordered an electronic ballast.
    In the past; my flat has had problems with mains transients, so I added an MOV and left the PFC cap in for a bit of filtering.
    Apparently; the more efficient electronic ballast gives the same light with only 20W - so the conversion pays for itself (eventually).
