about my power electronic exam
Discussion in 'Homework Help' started by ron8861, Jun 17, 2012.
  1. ron8861
    Jun 17, 2012
    IN the pdf file i have three question about power electronic
    in the first question inverter feed to the inductive load,S1 and S2 switches working half period(S1 open half period after S2 open half period)they are not open at the same time.you can see given values
    in a)plotting el,is1 and id1 graphs changing with time.
    in b)and calculate average currents on switch and diode.
    in second question buck converter;C has very big value,the switch open at 400microsec and closed at 400microsec too.with an ideal circuit elements a)plotting to the is,il and ic current graph
    b)calculate the load power in the steady state
    and last question 3 phase rectifier Ll has infinity value.with an angle a=0 value Vd=300V.For an Id=120A calculate a and commutation angle u
    please help me about this questions.in the first question the output current in the inverters io going to the rght but in this il going to the left.how can be the el graph in the second question i think ic current always become zero for an open circuit.D=1/2 and on the 2.5 ohm resistor we have 125V and how can be the il graph with this values.
    thanks from now for your helps.20 june will be last time.
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    I can't read whatever language this is in, but the indications are that this is a Final Exam for this course, not a review sheet or such. If so, then are your sure asking for help on it is allowed?
  3. ron8861
    Jun 17, 2012
    this is not actually a final exam questions teacher gave this questions and we will make them at home after one week we will deliver it to the teacher.i explain what means on the questions.it is not english!!
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    I know it's not English. What language is it, Norwegian?
    Thanks for the partial clarification. What are the ground rules for this assignment? It now sounds like a take-home final. Here, in general, take-home exams are expected to be solved without assistance from any source other than the instructor. What is the expectation there, for this particular assignment?
  5. ron8861
    Jun 17, 2012
    hmm there is no restriction in this exam.teacher said solve this problem and bring me..if he want to see how i solve them he said 'u must choose them alone and without any helping'..i just want to take some suggestions about these questions.i had some idea about these questions
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    The the first problem: It sounds like we are assuming ideal and instantaneous switching. Assume the system starts out with zero current and both switched open.
    Q1) Now start the thing working and close S1 for 50µs. How much current is flowing in the different branches of the circuit at that time?
    Q2) Now open S1 and close S2 and apply the continuity conditions for an inductor. How much current is flowing in the different branches of the circuit at that time?
    Q3) Now wait 50µs. How much current is flowing in the different branches of the circuit at that time?
    Q4) Now open S2 and close S3 and apply the continuity conditions for an inductor. How much current is flowing in the different branches of the circuit at that time?
    Q5) Does the answer to Q4 match the initial conditions? If not, then the system is not in steady state. If it does, then calculate the requested averages.
    Q6) Now repeat the exercise only close S2 first. Do you end up getting the same averages as Q5? If not, then the answers may depend on initial conditions.
  7. ron8861
    Jun 17, 2012
    what kind of formulas that i used in this current calculations.in ned mohans book there is nothing explaining about half bridge inverters i write google about half bridge inverters and i found different kind of things.just mentioned about with and instant voltage changing inductor current doesnt change instantaneously
  8. WBahn
    Mar 31, 2012
    18,087
    4,917
    Don't go looking for a bunch of formulas that apply to this specific circuit. Apply the fundamental circuit analysis skills that should have been the whole point of several classes leading into this course. Part of those fundamentals should have discussed what can and what can't changed instantly with regards to different components.
  9. MrChips
    Oct 2, 2009
    12,635
    3,453
    Turkish
    GEBZE HIGHER INSTITUTE OF TECHNOLOGY
    Electronics Engineering
    SCIENCE 629 Advanced Topics in power electronics
    Q-1: a figure of pure-phase inverter
    feeds the inductive load L. each
    switch S1 and S2, respectively, each half-peryotta
    açılmaktadırlar shuts down (or off at the same time
    not clear). E = 10 V, L = 100μH, and f = 10kHz
    According to that;
    a-eL, voltage and currents IS1 and ID1
    depending on the time to draw graphs.
    b-flowing through the switch and diode
    Calculate the average values ​​of currents.
    Q-2: The following step-down (lowering) DC-DC converter that is very large capacitor C
    Let's face. 400 μsec when the switch is open and closed. Ideally, the use of circuit elements according to
    a-iS, iL, and iC grfiklerini depending on the time of the draw.
    Steady-state power in case of b-Find the load transferred.
    Q-3: the figure of a three-phase rectifier load feeds from LL and RL. Infinite in size of LL
    is assumed to be. When the firing angle α = 0o Vd = 300V measured at the ends of the load. average
    Id = 120A load current to the ignition angle α and the angle of komitasyon find uo.
