about Mu.c programming
Discussion in 'Embedded Systems and Microcontrollers' started by siva, Feb 20, 2007.
  1. siva
    Feb 20, 2007
    hi everybody, i m doing final year engineering. i need ur help for my project.
    i'll give u the details of the project
    its about sensing the opening and closing of a door using IR sensors and then recording the opening and closing time with date.
    when there is no signal for the IR reciever,the micro controller should record the date and time.i hav decided to use 89c51.
    could anybody help me in interfacing the sensors and programming.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Could you tell us what about the sensors or the interface you are having problems with? The coding should be easy once you can use the hardware.
  3. Arm_n_Legs
    Mar 7, 2007
    183
    10
    Wouldn't it be easier to use reed switches to detect the openning and closing of doors instead of IR? I suppose you would also need a time display to assist in setting of the time and date.
