About Mosfet Heat sink
Discussion in 'General Electronics Chat' started by sonda, Dec 12, 2012.
  1. sonda
    Oct 30, 2012
    10
    i am using a N channel mosfet IRF 1405 to drive a 19A fan motor. the mosfet is controlled by a 10K potentiometer & 50K NTC. my question is what type of a heat sink do i need to use for this Mosfet. thanks In advance.
  2. #12
    Nov 30, 2010
    16,664
    7,311
    Huge.
    I think you just said you are using the mosfet in the linear region where P=IE and the voltage is unknown. Power = current times voltage. That's why mosfets are usually run as variable pulse width devices. Way complicated compared to just a potentiometer, but much easier to keep cool.
    sonda likes this.
  3. nigelwright7557
    May 10, 2008
    488
    71
    A huge one !
    Look up PWM controllers.
    sonda likes this.
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    You have to calculate the power dissipation, then select a heatsink based on allowable maximum temperature rise.
    sonda likes this.
  5. bountyhunter
    Sep 7, 2009
    2,498
    507
    However, if a FET is used as a "saturated" switch (fully cranked ON), power is calculated as:
    P = (I)squared X (FET ON resistance)
    sonda likes this.
  6. crutschow
    Mar 14, 2008
    13,473
    3,361
    What is the fan supply voltage? From the maximum power theorem the maximum MOSFET dissipation will occur when the voltage across the MOSFET is 1/2 the supply voltage but that's for a resistive load. Since the fan is a variable load it's more difficult to accurately determine the maximum power point, but it's likely to be no more than 1/2 the supply voltage times 1/2 the maximum fan current.
    sonda likes this.
  7. sonda
    Oct 30, 2012
    10
    its supply voltage is 12 volts. thanks a lot!
